I decided to take the corvette to work which is roughly 10 miles away. I drove all the way there and noticed I needed gas, so I pulled into the gas station directly across the street from work. I turned off the car, filled it up with gas and then my Viper alarm starts making a muffled noise like it was trying to go off but it didn't have enough power. I get back in the car, put the key in the igition and try to start it.....but nothing happens, no clicks, no turnover of the engine...nothing. In fact the car didn't even have power when the key was in the accessory position. I even tried the headlights and they were totally dead.
My first thought was the battery was dead. So I had a guy try to jump the vette (battery to battery). That didn't work. The engine didn't respond at all!
My next thought was the alarm was messing something up....so I disconnected it and tried to start the car....again with no luck (absolutely no power).
Then I start checking fuses and they are all good. Another guy asks if I need help, so we tried jumping the car from the remote solenoid I installed under the hood. It worked!! I drove all the way home, parked the car. Turned off the ignition and tried to start it up again with no luck.....totally dead again.
The car sat there the rest of the day and then at around midnight I got a knock on my door and it was the neighbor. She said my lights on the corvette were left on. Went outside and sure enough. All the corvette's lights, interior and exterior were on...I tried cranking and still nothing.
Next morning I pulled the ignition switch to find that the end had broken off and the spring was poking out the end. Replaced the ignition switch and everything worked fine.
My question is.... is there another electrical issue that still needs to be looked at? When I tried the lights at the gas station they should've turned on regardless of whether the key was in the ignition or not right?
(The car has a new tumbler, new ignition switch, all the fuses are good, new battery, new starter and new remote solenoid .)
Any thoughts would be appreciated!!
