C
cmegga
oK I have a new problem arising. I have an 81 rebuilt this spring, boared 20over eldebrock rpm heads, 600 cfm performer carb w/ eletric choke and a 3500 rpm cam.
The issues I have been having is at take off, when I hit it good of the off a stand still it cuts out on me. It only happens when I gun it, the car seem to cut out and I hear a pop out of the carb. Then a second later it comes back on. It almost feel like if you were to hit a rev limiter on a car that has one, except this is from a dead start.
It has been running fine other wise. I check the check and that is coiming off like it should.
Any ideas what could be the issue here??
