jbonifas
OK, it has been awhile, but I am resurrecting this topic again. I am still trying to get this thing from pulling to the right. The most recent alignment yoko couldn't get it either! (The right tire is 1/2" towards the rear of the car as compared to the left side. Also, there are no shims in the front of the right side and 6 in the rear.) The frame is not bent/ got it checked out. It appears that the upper control arm on the passanger side is bent as well as the spring may not be seated. I have always wondered about the springs, they are compressed to the point of several of the coils touching each other and making a metal on metal squeek. Anyway, I am replacing the front springs and upper control arm.
He also wondered how you may adjust the rear wheels. I am not sure if it is camber or caster, but the rear right needs to be adjusted. Help me if you can.
JCB
JCB
