L
leericardo
Just had a new set of tires from the Tire Rack mounted & balanced here in Lincoln...on my '92 Coupe with 66,000 miles. The installer has it up on the hoist and tells me I need both rear wheel bearings and the front right bearing. Expensive he says because of the ABS sensors in the wheel bearing assembly. He quotes $450 front and $250 ea for the rears, plus $300 for installation and $100 for alignment. Yes, I grabbed the tire and when "rocked" could feel a bit of play in all three, no play in the front left. He says they are "shot" when this is present. Is a bit of play normal or ok? And would it be ok to use the cheaper bearing assemblies available from MADirect or Ecklers...$550 vs. $900 for the parts. Do they all come with the speed sensors in the bearing assembly. Would appreciate input, thanks. ...Rick
