Wheel Bearing tool
PG-LT4
Westerville, Ohio
1996 roadster
Back in the good old days (late 60’s) when I worked in a service station (when they did more than sell gas) we had a hand tool that would insert the seal on the inside wheel bearing. This was a flat, round piece of aluminum about 3/8" thick. There was also a round bar, handle that you could wrap your hand around. The idea was to line up the seal on the hub, place the round, flat piece over the seal and tap the bar handle with a hammer.
This was a kit that had several different size round flat pieces that would fit several different cars.
Does any one know where I can find such a tool?
Almost any decent auto parts store will have a "seal driver set" with lots of different diameter ends that go on a handle - they're cheap. :)
