When have you checked your spare tire last...???
B
Black Ice
Just checked mine and it had only 12psi!!! So ya better look or ya might be sorry one day. Also check and make sure you have your lug nut adaprer and wheel lock! :SLAP
Missoura Ozarks
2012 💯 4LT GS Roadster
Dah . . .
2 months ago, it was out of air!
M
mds10134
Never really thought of it.:duh Thanks for the heads up!!!!
vigman
Motor head!!!!
Valencia, CA,USA
3weeks ago
When I put a new tire on the spare...for just such a party! ( Fixed the light back there too!)
Vig!
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
Checked my last week. Had a booming 20 l
bs........................:eek :eek
Thanks for the reminder.
cscarlson
SYRACUSE ,UTAH
2003 50Th Corvette
just before my road trip 2 wks ago, also put a 4 way lug wrench there too.
B
Black Ice
Yea I put a 4 way in mine also. My lug adapter is Awol.
B
Black Ice
Yup its that round dirty thing between the tailpipes, You know that rubber thing thats most likely FLAT!! :eek
C
C V Man
Hey, just put a run-flat under there and you're good to go!
C V Man
cash's90
Yucaipa, CA
1990 Charcoal Metallic Coupe
My spare was low but apparently never used. The jack was rusted but servicable. Cleaned everything up, sprayed the jack with WD-40, greased the screw & re-stowed everything.
V
VetpEtte
spare
My spare had 20 psi. It was like a jig-saw puzzle to get the spare back into the underneath compartment.
B
boblx2a
Spare tire?
When I bought my '85 one year ago with 37K on the clock I assumed it came with a spare tire. I know my '86 has one because I looked at it one time. I guess I better look down "between the tail pipes" for the dirty thing and be sure it is really there! :(
Thanks for the tip!
Gorgon
Philadelphia, PA
None
Flat and cracked. Getting a new tire tomorrow. Good thing to check before heading to PA in September.
vms4evr
Durham, NC
2002 Flat Black Z06
Just checked mine today. 5lbs. A tad low. Filled it up. Also found a ton of dirt stored in there and what looked like a retired birds nest! Well after cleaning the whole thing up I now have a working spare and shaved a few pounds off the car...
Graham
Ken
Gone but not forgotten
Hermosa Beach, CA
1987 Z51 Silver Coupe
Gee whiz guys!!
:L By now I would have thought that someone would have thought that by utilizing an extension (like those used for duallies) from the air valve on the tire, then running that out through the rear of the carrier and tied-off with a plastic tie. It will then be in a position where it can be accessed much easier, and therefore the spare tire air pressure can be checked more often. That's what I did. :D
I got mine through Griot's Garage but you can probably find it cheaper somewhere else. ;)
_ken :w
B
Black Ice
Yea someone else in here said they used that extension as well.
