Where do these hoses go on carb?
  • Thread starter Thread starter OneHotV6
O
OneHotV6
It's a base '70 coupe (350/300) with Q-Jet carb. There are 2 ports in the front with hoses coming out of them that are plugged with screws. Where do they suppose to go to? I can't find a picture or info about what they run to..
Thanks!
Normally ; one line is for the vacuum advance canister ; and the other for the vacuum pod controling the secondary opening of the Q-jet carb.
It's been a while since I've seen a stock set-up , but I believe I'm correct.
If your engine already has these hoses connected to the distributor and carb ; let me know.
Here's a pic of the carb, I didn't have time to use arrows but you can clearly see the two plugged hoses in front. Also, is that line on the side of the carb suppose to go to the vac advance? Hope that helps!
Thanks!!
Sorry - I can't help you , your distributor and pod are already hooked up.
