My FSM only has one paragraph about it, which is fine, but the diagram of location leaves alot to be desired. It shows an area with two relays in close proximity and points out which it is, but I have no idea where that area is on the car.
TWISTER gave you the answer, but for future reference, electrical item physical locations are in the Electrical Supplement. Look up the item in the electrical diagrams portion. Once you have found the item it will give you a diagram number/letter reference. Go to the back of the manual and you can then find the diagram to see exactly where that electrical component is located.
