Jeff Farrar
Ok. White flag. I give up. I spent about 12 hours this week replacing the all the lifters. The old ones didn't look that bad either. I took my time and made sure everything was real clean including brush blasting the intake. After starting it up, I let it idle at 2000rpms for about 15 minutes with it ticking or rapping away the whole time. BTW: BB's heat up running a 2000 for 15 minutes at idle. After I let it cool down for about an hour, I took off the valve covers again and watched the springs with the engine running at idle. The travel of all the valves looked the same. I really don't think it’s a issue with the springs or lifters at this point. Then again, I am no closer to finding out what it is either.
Here is what I found with a compression check #1-250, #2-225, #3-210, #4-225, #5-210, #6-170 (I know there it a ring issue with this one anyway), #7-225, #8-225. The engine is a "Hi Perf" stamped 4-bolt 454 with 13:1 compression and was really built racing and not really the street (which is how I want to drive it).
Assuming it is something in the bottom end, I guess I am looking at a rebuild which would run about 3-4k depending on what would needed to be done. At that cost, and since its not the original motor anyway, I'm thinking of selling it and buying a create motor.
Am I on the right path???
Old thread:
http://www.corvetteactioncenter.com/forums/showthread.php?t=69711
Old thread:
