Antz81
Having just fixed some fault codes with the ecm (13,23,34), the vette was running much better. Was a bit harder to start when cold but easier to start when warm. Was also idling fast due to better a/f mixture. OK, that was an easy fix, just adjusted the idle speed screw once warmed up. next for the cold starting problem, as the fast idle speed was non-existent figured this would be a good place to start. so adjusted this up to the correct speed, and watched while she warmed up. I began to notice some white smoke coming from the rear of the engine bay, and immediately shut off the engine. The engine tried to stay running for a little while but died after a few more seconds and clouds of white smoke came out of the air cleaner (intake ducts not currently fitted).
My first thought was white smoke = coolant, so possibly a head gasket. But other than the smoke and wanting to run on everything seems normal.
Wanted to check what she was sounding like after this (to listen for any odd noises mostly) let her cool down again and restarted from cold. This went much better (fired first time without any issues) and sounded completely normal but still the same problem presents itself. Checked for any ecm codes but got only the normal 12.
Am i on the right track with the head gasket? any other ideas on what it could be?
