Ken
Gone but not forgotten
I'm once again in a quandry here about what to do about installing longer wheel studs to meet the requirements mandated by many race sanctioning bodies, in my case it happens to be the National Hot Rod Association (NHRA).
My problem is finding the correct knurl shoulder diameter. All of the fastener manufacturers (Moroso, ARP, etc.) make studs with different sizes and applications:
My original wheel stud measures in at approximately .503" which is neither the first or the second choice in the above list. :confused
Please don't tell me that I must bore out the holes on my hubs and rotors to install studs that will meet the safety requirements. :cry
_ken
- Late Model GM Drum Brakes - 7/16"-20 x 7/8" press-in stud with .480" knurl - .472"-.479" hole
- Late GM Disc & Early Drum Brakes - 7/16"-20 x 7/8" press-in stud with .560" knurl - .552"-.559" hole
- Chrysler front and Ford Disc Brakes (front & rear) - 1/2"-20 x 3" press-in stud with .615" knurl - .606"-.613" hole
- Chrysler Rear (with 1/2" stud) - 1/2"-20 x 3" press-in stud with .685" knurl - .676"-.683" hole
- Aftermarket Axles - 1/2"-20 x 3" screw-in type fits all aftermarket axles with 1/2"-20 threaded hubs
- Frankland Disc Brake Hubs - 1/2"-20 x 3" press-in type features a .563" diameter knurl and quick-start dog end for use in 1/2" Frankland hubs
- Oval Track - 5/8"-18 x 3" press-in stud with .672" knurl
_ken
