gmjunkie
I need all weather strips for a 86!! I need a complete Kit,who has the best Prices and Fit?????
junk!!
junk!!
Tom, how would describe the process of changing out? any special tools or equipment needed? a real pain or ???
Thanks, Ted
I need all weather strips for a 86!! I need a complete Kit,who has the best Prices and Fit?????![]()
junk!!
Thanks!! I have no problem with the glue,I use KENT "Special Release Agent" spray them every 20-30 min and let soak a couple times, and pull them off glue and all!! Works good on Hood and Fuel door emblems too!! Makes the glue like rubber cement,roll it off and roll it up it Looks and Feels Like a Big Bugger!!Hey Junk,
I replaced my rear window, A & B pillar weatherstripping this summer. In retrospect, if I had to do it all over again, I'd get the OEM weatherstripping. Seriously.
The aftermarket stuff is cheaper, but the fit isn't dead-on perfect either. I bought LoneStar's product off of eBay. It wasn't bad, but it just missed on some of the finer points of contact. It also didn't have the internal wire running inside it like the stock w.s. does. That particular product also runs a bit thicker than stock. So, be prepared to take off your door panels to adjust your driver and passenger window fit.
A must-
Adhesive remover--the big can.
If you soak the old stuff right, most of it will pull out of the grooves. Then just use your weatherstripping tools--or screw driver, putty knives, etc..., to remove the excess. Get it all out. Make sure it's dry, then apply your adhesive. Good luck.![]()
junk!!
Where did you get Kent? Do they have a web sit? Thanks, Jack
That don't Look like the can!! Same Kent Insignia though!! Kent makes 100's of Body Shop and Dealership supply's!!! I get mine in Fla. from a buddy that has a Shop!!!
I do!! But I have 3 neighbors that don't!!!Junk,
Do you guys have indoor plumbing and/or electricity? :L
A salesman comes around once a month to the Shops and Dealerships!! It was the same when I lived in Mo.and Ill. But we don't have a man here!!(North Carolina is still in the Dark Ages!!there's alot of Great Products that no one has ever heard of here!!) Same with Snap-On and Mac!!! I have to go drive around a bigger city and find a Snap-On and Mac man making his Rounds here!!! 3M makes a stuff called "Release Agent" too, but it don't work as well!!!![]()
junk!!
junk!!
