Why angle plug heads?
MaineShark
Rockingham County, NH
1979 L82, 1987 Buick Grand National
Simple question, actually: what's the reason behind angle plug heads? I often see parts listed as "will not fit angle plug heads," so there is obviously a disadvantage to them. What's the advantage?
Joe
As I recall, when they we introduced the magizine guys said it was to get better flame travel. I don't know of any conclusive studies done to prove the value of angle plug heads. I doubt that you or I could feel a seat of the pants differance. Maybe a NASCAR team or national level small block drag racer would see them as worthwhile. Shoot, I'm happy when none of my 8 spark plugs are fouled and don't care where they point!
The advantage is mainly seen when using domed pistons, as the angled plug directs the flame front more effectively for use with a dome. They make little difference when using flat or dished pistons. :beer:
Joe
Header clearance also can be easier with angled plug heads.
CYa!
Allen
If you index the plugs (non-angle type heads) you get almost as much advantage as provided by the angle plug heads. The idea is to present the spark to the intake valve to give the flame front a more complete burn across the top of the piston thus more power. At least that's what the Big boys tell me.;shrug
Randy
