Will -94 exhaust fit an -88 Vette?
Doktor-t
Gothenburg, SWEDEN
1988 White targa automatic
Is it possible to fit the entire (from cats and back) exhaust system from an -94 Vette to my -88?
I got a welder so it won´t be any problem to hook up the pipes just behind the existing exhaust manifolds. I will also remove all cats. Hangers can I fabricate myself.
The tubing seems to be similary bent but do the fit?
Best Regards
//Tobias
no it will not work unless you fab the front Y pipe or have long tube headers. you will still have to fab some even with long tube headers.
compare an L98 exhaust to an LT1 exhaust.
is it hard? not really if you can weld and get some pipe bent your good to go.
I installed a 94 exhaust system on my 86. Rear hangers bolt up as is, others have to be modified. A little welding work on the front pipes and it's done. Easy if you have a welder.
