Will these headers fit?
Probably so ... but you'll probably need a different bracket for the air conditioning compressor ... just as you'd probably need if using any brand header. Similarly ... Check to see if your alternator backet attaches at any point to the exhaust manifold ... if it does ... you'll also need a different bracket for that too. Real common to need one or both brackets when fitting headers.
JACK:gap
