Window adjustment on 1999
  • Thread starter Thread starter ghfun
G
ghfun
Both my windows need to be adjusted for a better fit, to stop air noise and stop leaking. Can anyone direct me to an procedure for this ajustment. Aleady the drivers door rubs by the convertible top in the back when opening and closing the door so I do not want to adjust the back side up more. Thanks
A few people at the Corvette plant told me a few weeks ago there's a few adjustment bolts used to adjust the tilt in/out of the windows. You probably need to tilt your window in to put a bit more pressure on your window seals and this might just help on the rubbing of you top issue also.
I hope this helps.
Later . . . . . .
6 Shooter
Hey thanks for the info !!!!!!! Maybe I can leave the towels at home when I go out cruzin' in the rain.
