T
theplayer
I searched the forum for this and found tip in/out directions but no directions on how to limit the up/down adjustment. Has anyone adjusted the up/down of their window? I know there are holes on the bottom of the door but the access to the hardware from the front hole is limited. The rear hardware is easy to get to but I think that it just lowers the rear part of the window. I need to lower the window in the front about 1/4" because its pinching the weather stripping. Does the door panel have to be taken off or is there a way to adjust this from the access holes?
