A1Avette79
ad My passenger power window keeps eating the regulator about 1 inch from the top. Motor is new, regulator is (was) new, tracks are all clean and lubed. This is the 2nd regulator I've put in and both work for a while then the motor eventually wears the teeth off the regulator in a approx. 1 inch strip about 1 inch from full raised. Is this an alinment problem?
Has anybody tried the regulator repair kits where you rivet a new set of teeth to the regulator?
Trenton
Trenton
