T
Turtle
If your windows rattle and / or leak like mine did - an easy partial fix is to replace the guides. They help to keep the window firm and in place. You'll need 2 for each door and they are about $10 each. Take the door panel off - and at the very top, you'll see them held in by a single 3/8 bolt. Make sure to grab them with something so they don't fall into the door when you pull the bolt out. You may want to oil up the old bolt and try it first as the new ones will have tight threads. Then - you hold them in place with some nn pliers or something and try to line them up where the old ones were. Check you work and make sure the window isn't too tight and you're done. Took an hour or less per side.
Good luck - T
Good luck - T
