K
kdlp
I have a batch of loose wires/pluds, etc. under my hood and am hoping someone with an L-81 might be able to tell me what they're hooked to. I suspect they may be involved with the emission/computer gear as this car was repowered and the emissions gear was not used.
Two of the plugs are six conductor plugs that appear to be male and female. They come from a wiring loom at the firewall a little right of center near the valve cover. With them is a smaller 2 conductor plug with a brown and a black with brown stripe wire.
Finally, there's a single wire (black with green stripe) that comes through the firewall from the fuse box (right side of box), comes through the loom and then terminates with a GM type plug just above the left front wheel well. There's a pic of this last one attached.
Any help or ideas?
Thanks,
kdlp
(kelly)
Any help or ideas?
Thanks,
kdlp
(kelly)
