WTB: ABS Control Module for a 95'
  • Thread starter Thread starter CAJUN C4
Before you buy, check very carefully because a 1995 Corvette with the LT1 engine does not use the same ABS controller (EBTCM) as does a 92, 93 or 94.
92-94 (ABS-IIS) is one controller and 95-96 (ABS-V) is a different controller. Also the 95 and 96 controller and brake valve are one assembly.
http://www.corvetteactioncenter.com/tech/c4/abs/
Only 95 ZR1s use the ABS-IIS controler, ie: 92-95 ZR1s use the same EBTCM.
For more information on C4 ABS diagnosis and service, see:
Corvette Action Center | Tech | Stop to Match the Go - All About C4 Antilock Brakes and Traction Control
Hib:
As usual your a Life Saver.
In your opinion,You think it would be very difficult to change out?
I believe I found one from a 95'
Thanx Again
Dennis
