WTB DS Door "Control Assembly"
hzl6cm
Odessa, MO
1970 Laguna Grey Convert., '04 Z06
This is the unit that the inside door handle screws on to. On the assembly manual it is listed as 3966719-20 Control Assembly. I need it for the driver side door since the part that the door handle slides on to is broken on my car and the only way to open the door now is to use the outside door handle. Thanks.
Kevin
did you try Chicago Corvette? several other vendors no offer these without cores for around $40.
Thanks for the info - I will look there. I had seen some elswhere for about $69 which I thought was a little steep.
I see that you are from Mitchel, we drive through there several times a year on our way to the Black Hills and my wife and I first got together there at the Motel 6 24 years ago (before we were married and just after we first met) so we always have to point that out as we cruise past that Mitchel exit on I-90!
Kevin
Small world. Hope you like the Hills. The monument is really first class and awesome after the remodeling.
