WTB VBP Offset Upper Control Arms
  • Thread starter Thread starter Sky65
S
Sky65
Looking for a pair of VBP offset upper control arms. The ones that allow additonal caster and camber adjustments. I thought I saw some for sale a little while back but I cannot find the add.
Tom
Tom,
I did not post anything but I am toying with selling my setup. I would need to sell the complete setup or nothing. I have vbp's uppers and lowers, composite spring, and qua1 dbl adj. shocks. They have been bolted up but no miles or weight put on them. New they were uppers-329.95, lowers & spring-789.95, shocks-277.69 each (total 1675.28) without tax or shipping. I would sell for 1400 plus shipping for all. There is pic under my profile.
Chuck
You can also install cross shafts in your original control arms that will give you more adjustment range . I think moog sells them and maybe trw . I have used them with good results.I suppose it depends on how much more offset you are looking for Steve
Wilkinshc said:
Tom,
Chuck
Chuck
Thanks for the reply. I have new VBP coils, sway bars and shocks so I will have to pass on the whole set up.
Thanks again.
Tom
Will these allow more positive caster? I have lowered the front end and have a Steeroids set up to put on. Steeroids recommend as close to 5* positive caster as you can get.
Tom
I do not know if you would get that much a lot depends on the condition of the frame it would add at least 1 degree caster on top of what you already have and depend on how much camber you are going to use
