Xm
From 'z06nut' on Z0Vette.com Forum
"I put little black silicone rubber pads (like the kind they put on the inside of a drawer or cabinet door to keep it from banging when it shuts. Got 'em at Radio Shack) on each corner of the underside of the antenna. They act as soft standoffs, and keep the underside surface of the antenna from touching the car body (I didn't want the antenna scuffing up the paint if it happened to get moved around). Inside the trunk lid, facing up, I have a big-ass magnet I took from an old Disk Drive (you can probably get a similarly powerful rare-earth magnet at Radio Shack, too). The magnet holds the magnetic antenna mount to the decklid just fine. The rubber feet keep the antenna from sliding around on and scratching up the paint.
At one time I actually had the antenna mounted on the center/bottom of the rear window. The rubber feet on the antenna let it follow the curve of the glass without rocking, and the magnet worked through the glass just as well as it does through the plastic body. It actually looked a lot better there, but the reception wasn't as good so I went back to the Deck Lid.
The antenna really wants to have a "ground plane", a conductive flat plate, beneath the antenna itself. Ground planes improve antenna reception. On a steel bodied car, the body panels serve this purpose. On a Corvette there is no steel = no ground plane. I considered putting a flat plate (aluminum foil would do just fine, thickness doesn't matter) under the deck lid (it doesn't have to touch the antenna, it just has to be reasonably close). Killed the idea because there was no way to make it look decent. Terk makes an antenna for trucks and boats that doesn't need a ground plane. It's huge, but I bought one anyway. Used it inside the car (plastic doesn't work as a ground plane because radio goes through it, so there's no reason the antenna actually needs to be on the outside of a Corvette). Unfortunately, my 02QS has metal flake paint, which does a good job of blocking the signal. The antenna inside worked, but not very well. I just gave up and got the smallest antenna I could. It works fine even without a ground plane. I have XM in my wife's Sierra truck, which is all steel, and it doesn't work very much better."
Derald
