Z06 Exhaust on a 2002 Coupe
  • Thread starter Thread starter JayK
J
JayK
Does anybody know for sure if the Z06 titanium exhaust fits on a 2002 coupe? If so is this change relativly easy to do?
If you are talking about the pipes that go over the axles and the mufflers and tailpipes, its a direct swap out. Takes about 1 hour, provided that you can get the car up over 30" or so in the air. Its only 4 bolts and 2 hangers. Only prob is the passenger side gas tank shield - you may have to remove it/move it around to get the passenger side pipe. A muffler shop should charge you less than 1 hour labor plus a lift charge. If you are looking for a more mellow sound, then the Z06 works well. Would recommend the Z06 air box.
Thanks guys! Im def physched to pick up the new Z06 exhaust. Ill let you know how it turns out.
