cadmando
I'm looking at a 2001. They replaced the stock rear-end with a Z06. What effect will that have on the overall performance? Or bad effects?
Thanks,
:confused
Thanks,
:confused
The gear ratio on all 6 spd C5s was 3.42:1. The Z06 differential gears were shot peened for added strength, that's the only major difference from the normal C5 differential.cadmando said:I'm looking at a 2001. They replaced the stock rear-end with a Z06. What effect will that have on the overall performance? Or bad effects?
Thanks,
:confused
Shot peened means the gears have been treated by blasting steel shot at the gear surfaces, this strengthens the gears by changing the density of the metal, making the gear more resistant to torque impact loads.cadmando said:What does shot peened mean? Is the gear ratio different? Also it has automatic transmission if that makes any difference
Jim
DRTH VTR said:It means that it will accelerate faster, but the engine will turn faster at any given highway speed compared to a stock rear end. The upside is better acceleration, the down side is slightly poorer gas mileage.
