Z07 Build Comparisons
  • Thread starter Thread starter pionex_80
P
pionex_80
Thanks to Tom and his work there will be a decent Z07 registry. But I guess I wanted to know more about Z07s and therefore would like to compare our build sheets as well. And maybe we could find more unusual and interesting information about this little known version of the Corvette. I will start with mine. Thanks to all Z07 owners that share their information. And again - Thanks Tom!
AG1 - ADJUSTER, FRT ST, POWER, 6 WAY DRIVER, SPLIT BENCH
AG2 - ADJUSTER, PASS ST POWER, 6 WAY, SPLIT BENCH
AK5 - RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 - SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU0 - LOCK CONTROL, REMOTE ENTRY – KEYLESS ENTRY (DOMESTIC)
BGR - BOWLING GREEN PLANT PROCESSING
CF7 - ROOF, SUN REMOVABLE NON-TRANSPARENT
C68 - HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC
DL5 - DECAL, ROADSIDE SERVICE INFORMATION
DL8 - MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
FE7 - SUSPENSION SYSTEM, FRT & RR HD, VAR 3
FE9 - CERTIFICATION, EMISSION, FEDERAL
FX3 - RIDE AND HANDLING, AUTOMATIC ELECTRONIC CONTROLLED AAA
GM3 - AXLE REAR, 3.45 RATIO
IP3 - Interior trim design P3
J55 - BRAKE SYSTEM, HEAVY DUTY
KG9 – GENERATOR, 140 AMP
LT1 - ENGINE, GAS, 8 CYL, 5.7L, TPI, HO
ML9 - TRANSMISSION, MAN 6 SPD, ZF, 90UM, 2.66 1ST, O/D
MN6 - MERCHANDISED TRANS, MAN 6 SPD PROVISIONS
NA5 - EMISSION SYSTEM, FEDERAL, TIER O
NK4 - STEERING WHEEL, SPORT LEATHER
QA1 - WHEEL, 17 X 9 S, ALUMINUM, STYLED
R7A - Control sales item 26 special option processing
UX0 - SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE
UIF - RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
U52 - CLUSTER INST, ELECTRONIC
U75 - ANTENNA, POWER, RADIO
VM3 - Label Information Consumer, Contains Bumper Impact Standard for Front 5 MPH and Rear 5 MPH *Processing Option*
V73 - VEHICLE STATEMENT, USA/CANADA
XAU - TIRE FRONT, P275/40ZR17/N BL R/PE ST TL HW4
YAU - TIRE REAR, P275/40ZR17/N BL R/PE ST TL HW4
Z07 - PERFORMANCE PACKAGE, AGGRESSIVE SPORT
1AY - STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1SB - OPTION PACKAGE 02
19I - INTERIOR TRIM, BLACK (I) (91)
193 - TRIM COMBINATION, LEATHER, BLACK (3) (91)
75U - PRIMARY COLOR, EXTERIOR BRILLIANT RED MET (91)
Sorry about the late reply, but better late than never
Here are my 93 Z07 Build Sheet Codes:
[TABLE="width: 128"]
[TR]
[TD="width: 64"]AC1 POWER PASSENGER SPORT SEAT
AC3 POWER DRIVER SPORT SEAT
AJ3 AIRBAG
AQ9 SPORT SEATS LEATHER
BGR BOWLING GREEN ASSEMBLY
C2L DUAL REMOVEABLE ROOFS
C68 AUTOMATIC ELECTRONIC AC
DL8 TWIN REMOTE HEATED MIRRORS
D3X SPEED GEAR GREEN 25513049
D8I SPEED SENSOR 10456089
E5Z DELETE SPEEDO ADAPTER
E9Z DELET SPEEDO KET
FE7 HIGH PERFORMANCE SUSPENSION
FX3 SELECTIVE RIDE HANDLING
GM3 3.45 REAR
IL3 INTERIOR TRIM L3
J55 HIGH PERFORMANCE BRAKE PACKAGE
KG9 140A ALTERNATOR
LT1
ML9 6 SPEED
MN6 6 SPEED
NA5 FEDERAL EMISSIONS REQUIREMENTS
NK4 SPORT LEATHER WHEEL
QA1 17X9.5 WHEELS
R8S CONTROL SALES ITEM 68
R9Z CONTROL SALES ITEM 100
UU8 DELCO/BOSE AM/FM STEREO WITH CASSETTE
UX0 DELCO/BOSE 6 SPEAKER SYSTEM
U52 ELECTRONIC INSTRUMENT CLUSTER
U75 POWER ANTENNA
V73 US OR CANADA
XAU 275/4017 FRONT TIRES
YAU 275/4017 REAR TIRES
Z07 ADJUSTABLE PERFORMANCE HANDLING PACKAGE
Z25 40TH ANNIVERSARY PACKAGE
1AZ MODIFICATION STOCK ORDER OR ORDER SOLD
1SB MARKETED OPTION PACKAGE 2
64S BRONZE ROOF PANEL
68U RUBY RED MATALLIC PAINT
79I RED INTERIOR
793 RED INTERIOR
[/TD]
[TD="width: 64"][/TD]
[/TR]
[/TABLE]
1993 40th Ann Z07
Since my post in July, i have purchased a second 40th anniversary z07.
At this point I have two identical cars...its kind of cool.
One has 130k (I put 4k on it roadtripping last summer!) miles, the other has 30k miles. They both drive/ride about the same.
Does anyone know production numbers of 40th anniversary Z07s?
Anyone know of any Z07 specific resources?
Cheers,
Chris
