c4c5specialist
Technical Advisor
In order to check the transmission fluid level on a Z51/manual equipped car.
The vehicle MUST be running in neutral and the fluid temperature must be between 80-122 degrees F. The pump, which is run off the countershaft must be running because fluid has to be pressurized into the lines, for accurate fluid level.
This is only on Z51 equipped cars, not the standard MM6
