C
CSDMagred01
Anybody seen a comparison of the 2 kits on the base suspension car or driven both upgrades? Usually people are happy with the upgrade they buy but haven't experienced both. I think they will give different front to rear balance. Here's why I say that and why I've been considering the Z51 kit.
1) it was developed for the coupe
2) the thicker Z06 bar will just give more understeer on a coupe than Z51
3) the front bar is thicker on the Z06 because the Z06 is lighter in the back (less glass). In other words with the rear bar being the same and working against less weight, you need a bigger front bar in the Z06 to restore the front to back balance. Not true in a coupe
This seemed to make sense logically but could be totally wrong. Since no one has done an analysis one way or another I haven't bought either. Ideally I'm looking for a back to back test on one car of both front bars with the rear one. That really won't be hard to do, if you're doing the upgrade. Alternately 2 cars set identically except for Z51/Z06 front bar and compared by the same driver could give an answer.
For me, the cheaper Z06 kit is a good savings, but the importance of $50 fades when one end of my car continually breaks out early when it shouldn't. That would leave a bad taste every day I drove the car.
I guess I could buy both fronts and a rear and try it myself, but I'm not THAT interested in buying a front bar, I know I'm not going to need.
Thanks,
Thanks,
