zr1 1992
  • Thread starter Thread starter johnny
J
johnny
I have a interest of buying a 1992 zr1. Who can give me some information about zr1's in this particulair year? What are the options what you could buy in this year? Are there hidden problems where I should look at?
Does anyone knows in what kind of colors the ZR1 is build? I only know red, yellow, black and metallic dark green. In any year ofcouse.
Are there differences in the axels between 1990 and 1992? (I have some wheels to fit under....)
What about milage? 10k 20k 30k or maby more??
Thanks for the help.
John
Almsot every question you have can be answered here. www.zr1.net
Only one. The choice of having both tops.
http://www.zr1.net/ZR1_issues.html
Black, Black Rose, PG2, Quasar Blue, Aqua Metallic, yellow, White, Bright Red, and Dark Red Metallic.
From one ZR-1 to another no. But from a narrow body yes. ZR-1's used a 36mm offset in the rear while 88+ cars use a 56mm.
What about mileage?
thx for the info.
I have been on ZR1 net and find lots of information, but some info of real zr1 owners or who have some experience with might help some more.
What is it why a ZR1 drives better than a normal C4? The ZR1 is heavier than a normal corvette. Is the chassis stronger? It is wider at the rearsection, but is it actually stronger or stiffer? Is there a difference in gravetypoint? Maby is the engine deeper located?
Are there any points at a ZR1 what could be improved? I heard that change the radiator and the brakes would be a good choice.......
Is there any difference in the weight of the hood vs normal C4?
join the zr-1 net
johnny join the zr-1 net yahoo group member listing..it is free to sign up...ther are tech and non tech posts everyday and after you read them you will learn all about the zr-1 and the lt5 plus you can access the old post sections as well not to mention all the data off the home page to various sections ie: troubleshooting and maint.
