- Thread starter
 - #21
mdevese
- Joined
 - Aug 27, 2007
- Messages
 - 24
- Location
 - Texas
- Corvette
 - 2002 Spiral Grey with double dark grey stripe
Hi c4c5 specialist,
I have taken the left check valve off and blown through it both ways, the rubber tube side (into the manifold) air passes, the threaded side (manifold side that should be closed when blown) air did not pass by mouth. While I had it apart I disconnected the 5/8 tube by the washer tank, started the engine blocked the pipe and had air pulsing from the tube that would go onto the check valve I had just removed. Does this mean that the check valve behid the engine that goes to the right bank is faulty? Ant thoughts on this mate. Thanks
Michael.
Michael.
