vette-dude said:74 Bigblock,
You know sometimes I think if you didn't have bad luck, you would have no luck at all!! Glad to see you finally seem to have the problem resolved. What a PITA but guess that's just part of the program. Keep us posted and use the duct tape sparingly on re-assembly.
Randy![]()
madvette74 said:GOT a question in regaurds to differential fluid, I tried to get penzoil synchromesh, I went to pepboys, auto zone and another local parts place, none have heard of it.. where can I get it??
well I got 3 quarts of GM synchro fluid at 10.50 each.. and 3- 4oz of posi lube at 8.50 each (bought extra) and 2 quarts of penzoil GL-5 for 5.00 each... I can only guess my tight shifter in 1st and a little in 2nd has to do with some sludge that came out of the trans (manual) we'll see if the problem goes away.. also when I fill the trans, the car needs to be jacked on one side, I think this may cause a little more fluid being in there, when the car sits level. will this be a problem?JohnZ said:There's nothing special about 80W90 diff lube - just go to your Chevy dealer and get GM Diff Lube and two 4-oz. bottles of Posi additive and you're in business.
ad .. the only good thing that came out of this was, when I drained it again, the oil looked like it had very dark clouds in it with a bit of foam..
so atleast I got more junk out..Hell Dave!! Just send it to Me for Tech advice!! You'v got'er Big Boy!!74bigblock said:I just received a provisional credit from my bank in regards to this fastcorvette fiasco. I've been minus $3396.75 since my order on 6/15. Today is 8/4. :ugh
Not to mention the additional expense of having to purchase everything again from another vendor! I was really out like 6 grand until now!
Never ever EVER do business with fastcorvette
:gap junkie!!dk1977 said:74bigblock--- received my t-arms today from Fastcorvette. Only took 45 DAYS! Glad i was in no hurry.... After initial inspection everything looks as promised. I will check end play and all else before installation. Good luck on your problem!
