My understanding is that few if any drag radials are available in the C7 rear sizes. If that's the case, you have to go to a smaller diameter wheel. When you do that you also have to consider clearance between the brake caliper and the inside of the wheel. You also have to consider the diameter difference front to rear. If that gets to be much different than stock, you'll have problems with the ABS.
