V
Vettemandon
I thought when I tore my '60 apart in 1985, that I had everything covered. I bought zip lock bags, a Michaelis AIM, took pictures, labeled everything, bought boxes to put the parts in, etc. Well, I was wrong. I'm now getting the interior in it and I've run in to a problem. The passenger side kick panel (GM# 3749210) and the dash panel extension (GM# 376211) mating. The section of the extension panel that comes down toward the floor on the right (outboard) side mates with the passenger side kick panel via two trim screws (GM# 162406). These trim screws go through a 3/16" hole on the dash extension panel, then through a 5/16" hole on the kick panel. From what I can see in the AIM, section B, Sheet 4.00, there are spring nuts (GM# 445393) that, it appears, the trim screws secure to, thus holding the extension panel and kick panel together. The spring nuts would have to fasten to the kick panel (in the AIM, this is apparently referred to as the "cowl side trim panel R.H."). Spring nuts ("j" nuts) just won't work. What am I missing to be able to secure the extension panel to the kick panel? I'm trying to be as original and stock as possible. Would appreciate any help as to what in the world I am not seeing. I would like to say "thank you Corvette community" in advance for your help.
