MoeJr
Can anyone give me the info on the stock heads used on the 327/300hp engine from 63-67. I am looking for casting numbers and valve sizes along with chamber size. Thanks in advance.
Hi Moe Jr,MoeJr said:Can anyone give me the info on the stock heads used on the 327/300hp engine from 63-67. I am looking for casting numbers and valve sizes along with chamber size. Thanks in advance.
If that's from the latest NCRS Spec Guide, it will be corrected for the next issue so it matches the Judging Guide; late 67's used the 3917291 from about April on. My June 1st 327/300 has the 291 heads, dated late May.Fuelie said:'67 all engines = 3890462
Brian
Hi John,JohnZ said:If that's from the latest NCRS Spec Guide, it will be corrected for the next issue so it matches the Judging Guide; late 67's used the 3917291 from about April on. My June 1st 327/300 has the 291 heads, dated late May.
