1963 327 engine complete from air cleaner to steel crankshaft. Block is standard bore casting number 3782870 dated L-13-2 and stamped J179687 F1217RB. One cylinder has a quarter size hole which would require a sleeve and it is from a rod hitting it when the block locked up in the early 1970's. I can have it fixed but wanted to show the damage.
1963 #3782461 X heads both dated L-15-2 cleaned and magnafluxed.
1965 Intake #3844459 dated B-6-5 with AFB Carter Carb with tag. Intake shows to be a service replacement used from 1963-65.
Exhaust manifolds #3797942 & #3797901
Steel Crankshaft uncut
8 rods and seven pistons (pistons no good) but are factory
Water pump with pulley and fan blade
Crank pulley
Factory Air Cleaner
Factory Turbo Fire Valve Covers
Factory timing cover
Factory head bolts, intake bolts and valve cover bolts
Other miscl. pieces with it
Can ship and asking $3,000 for all of it. Any questions I can be reached directly at 330-770-2517. I live in bowling green ky 42101.
Crank pulley
Factory Air Cleaner
