I have this up but accidentally put it in with the car section so wanted to relist it in the correct spot. 1963 327 standard bore block casting number 3782870 dated L-13-2 and stamped J179687 F1217RB. The block has a small hole in one cylinder so it will need sleeved which I can have done but wanted the damage to be seen by the new owner.
3782461 X heads both dated L-15-2 cleaned and magnafluxed
Exhaust manifolds #3797942 & #3797901
Intake #3844459 dated B-6-5 (service replacment 1963-65) with AFB carter carburetor
Water pump with pulley and fan blade
Crank pulley
Air Cleaner
Turbo Fire valve covers
Heads bolts
Intake bolts
Valve cover bolts
Factory Steel crankshaft uncut
Timing Cover
Asking $3,000 for everything and can ship if you cannot pick up. Located in Bowling Green KY 42101 and can be reached for any questions directly at 330-770-2517.
Crank pulley
Air Cleaner
Heads bolts
Intake bolts
Valve cover bolts
Timing Cover
