1968-69 ZL1 #3946052 aluminum tall deck block dated 06017 on backside and is a standard bore 4.40 bore. Block was pressure tested and is a good rebuildable core $8,000.
1969 ZL1 NOS block #3946052 dated 3-1-69 with no stamping on front pad and stamped on underside by spin on oil filter of T 08 0. This was supposed to be a counter exchange block but was never run. I have the 4296 holley carb dated 893 needs rebuilt, 3946074 aluminum heads dated 8-22-70 & 10-1-70, 3933198 aluminum intake dated 8-10-70, 3975928 aluminum water pump, 7115 steel crankshaft standard with 7/16 dimple rods and a replacement set of factory TRW pistons with internals all balanced. Engine had all new sleeves installed and is ready to build. $35,000 for the engine.
330-770-2517 for any questions. I can ship if you cannot pick up.
