For Sale 1968-70 BBC 427 Warranty Exchange Block, Square Port Heads & Parts
Use this thread prefix to post for sale items.
dlv4540
Ohio
1968 3919840 square port heads rebuilt dated E-20-8 & F-13-8 with L stamped rockers $2,000
1968 3919840 square port heads with dates of
H-24-7 $750
L-11-7 $750
A-28-8 $750
C-13-8 $750
1968 L88 427 factory TI distributor #1111295 dated 7 H 14. Distributor was converted over to points but I have the NOS GM transistor ignition system pole #1960779 to make back to factory correct $1,000
1969 3919840 square port heads with identical date codes of L-18-8 $1500
1969 3919840 square port heads with date codes of
L-4-8 $750
A-16-9 $750
A-22-9 $750
1969 427 4 bolt standard bore block casting number 3963512 dated F-4-9 stamped CE970793. This is a warranty counter exchange block that will come with 6223 steel crank standard checked and greased down, dimple rods, 8 inch harmonic balancer and timing cover, windage tray and bolts along with the original camshaft $4,000.
Can ship if you cannot pick up and can be reached at 330-770-2517 for any questions or pictures needed.
