61 Silver
1963 SWC Update
Hi!
I have been making steady progress on the restoration of the SWC. I thought it was about time for a few photos and an update. Then I can harass studiog for an update on his 61!
The differential is almost restored (new barring and seals) and I should have it and the trailing arms home next week. All the parts that needed to be painted black have been DP-90 and are coated with a black single stage urethane. The parts have been sprayed with different sheen black paint. The body mounts that are located in the engine bay have been replaced. The engine bay was primed with a high build K-36 primer and sprayed with black out paint. This should have been done after final paint of the body, but I only want to mount the body once and will be painting it after I have shimmed it to the frame and correct bodylines and gaps. The new frame has been sand blasted and will be sprayed with PPG DP-90 and a semi-gloss urethane. The A-arms have all new bushings and I hope to rivet the ball joints in this weekend. If everything stays on schedule I hope to start installing the rear and front suspension on the frame early next week. I still have to check out the Muncie transmission and if everything is ok with the transmission I should be able to set the drive train the following week.
This is my favorite part of the restoration. Working with clean parts and watching the Corvette start to look like a Corvette again.
I will post additional pictures as the restoration proceeds.
Ray
Hi!
Ray
