vigman
Motor head!!!!
- Joined
- Feb 13, 2001
- Messages
- 3,471
- Location
- Valencia, CA,USA
- Corvette
- 88 Convert ( SOLD ) /1973 coupe 4 speed/1964 Vert!
So considering I do not have enough room with the 461 to bring the engine into correct timing by just doing the " twist ".
AND the mission today is to put the chrome doghouse on AND have the timing correct!
( trying to get 4~10 degrees of range ), because there isn't much swing with the doghouse, tach cable & 461
Facts:
The vac advance CAN is hitting the intake and we are at "0" TDC W/O vac hooked up...
The distributor rotates clockwise..
Twist the distrib CCW to advance
Research"
I read " somewhere "
<tbody>
</tbody> and IF you divide 360 by 8 that's 45 (I assume degrees)
so I would want to move the the distrib 1 tooth clock wise to make it work properly....
But then I over think things and consider that the 6 degrees target is BTDC ( to make it happen earlier ) and that leads me to think 1 tooth CCW...
Since advance is twisting the Distrib CCW.. and 1 tooth would advance things ~ 27 degrees causing me to back off on the distrib CW ( pulling the Vac advance can so it ins't hitting intake runner ) ...
AND
Moving the wires gets me WAY to advanced ( over 30 degrees )
HELP ?
Mike
Facts:
Research"
the distributor is off at least one tooth. Each tooth is ~27 degrees. |
<tbody>
</tbody>
AND
HELP ?
Mike
