timme69680
This is actually a pretty simple question, but I thought i would ask before breaking out the drill. It appears that I have to drill out the ball joint cover/grease fitting to replace it. What size drill bit should I use to do this, or should I drill it at all? Here is an image of the part prior to any restoration, it will be sandblasted and powder coated when it is all said and done.
http://www.helptimmebuyahonda.com/rebuild/suspension/a-arm-5.JPG
