I,m guessing that you are referring to the rear pilar. They are pop-riveted on from the back. Remove the trim, where seatbelt comes out. Once that is moved out of the way you will be able to see the pop-rivets. Then drill the rivets out and then you can remove the seal. Sometimes the seals are also glued.How do you remove and replace pillar weatherstrips and also the door posts on my 1980 corvette. I have the new 9 piece kit .
ad ;help :W
