corvette66
I just got a 1980 camaro Z28 the other day with the original motor etc. I noticed after pulling the engine apart the heads are the same 264624 heads as the vette with the same valve size (typical 80's cylinder head) cam measures about the same as my 80 vette also with about 400-420 lift.
The only difference i could find was the intake on the vette is aluminum.
Was there any difference? the camaro spec was 190 HP not sure what the vette was in 1980.
just curious, the vette is much faster and the motor has twice the miles as the camaro. Rear end gear is about all i can figure. both have 400 trans and stock quadra junk
