Ludigdrums
Another View...
I realize this is an old thread, but I just found it (just joined) and wondered if anyone still has a picture they could post to show me how that front spoiler/valance is supposed to look? Mine's draggin' too!mikejpss said:yes sir, your're making sense- sounds like the same problem, however, i can not understand how you made an adjustment to the metal bracket and still have the bracket "hold it tight". This is why I'm asking for a pic, to see what the standard is suppose to look like. The metal plate/bracket (on mine) has a metal hook-like piece on the rear of the bracket. This hook-like piece was (when I bought the car) underneath the valance, holding the valance up and obviously, too high up. Still confused as to how this metal hook plays a part....
Now I hope that I"M making sense.
Man, a couple of close up pics would surely help.
Mike J.
Thanks, Bill. We are talking about the same thing. Only question I now have is why, if those brackets are in the back, does the front of the air dam on mine droop like it does? :confusedbill81vette said:the triangular thing should be urathane not fiberglass,as is your bumpers if iys original,so if you prrk to clse to the sidewalk,(nosein)you wont break the fiberglass,if you look at the pic here I pointed to where the valance or air dam is the pic I took in my previos post was from undernearth and behind the air dam.
I looked at your pix again, and just realized why you have urethane...it's a bottom portion that is totally missing on mine! The upper portion is fiberglass, but the lower, black portion is missing on mine! (so is the metal hook). It took me a while to figure out why yours looked like it was deeper than mine and had a hole in it!herron said:BTW, mine still looks like fiberglass!
mikejpss said:KC-21
finally found it, after much searching- which means you owe me a beer ....![]()
Go to Willcox Wholesale Corvette Parts home page and type in "spoiler" on the search bar. You will be taken to eBay's site where Willcox has 2 sets of these spoilers up for bid starting at $65, or a "buy it now" price of $70. This is for a set of 2 pieces.
These are good people to deal with ,I have had no problems from them thus far.
Let us know how things come out
:Twist
Mike J.
Tom Bryant said:This is my wife's '81. She ordered the car and took delivery of it in October of '80 (early St Louis car). As you can see the paint is scratched off a little but it isn't bent. This is all original and has never been damaged.
The first picture is a 3/4 front view. You can see the tab protruding horizonally back through the slot in the rubber spoiler extensions. The valance is supported by this but there is no bolt. or hole for one. If the bolts are correct on the cars so equiped there must have been an engineering change somewhere during the production run.
No such luck, Bill. The hook is gone. I can see the back of the impact bar where it sheared off...and I'd be willing to bet this front spoiler is fiberglass, not urethane...must not be original. It also seems to be missing ALL the bolts in back that hold it in place! (I can see where one looks like it is sheared off in the hole!) I don't know why this didn't fall off when I drove it home from the previous owner!bill81vette said:the upper portion should be urethane(oem) the bottom portion (black) is rubber!
some time the metal hook get rolled up behind the steel bumper(impact bar) and just needs to be moved back down and reset into postion.
good luck!!
