Just to clarify, NO power at fuse block where circuit breaker is inserted, ignition on or off.
Pink wire firmly connected to fuse block. All other vehicle accessories functioning normally,
ie., power door locks, antenna, interior courtesy lights, etc...
I have no 25A fuse receptacle. It appears fusible links are intact. I can't seem to follow the pink power wire from
out behind the fuse block into the harness that comes in from the engine side. I am assuming that the problem
is on that side. The wiring diagram I have is made for a 20 year old with perfect vision to read.
. For now I'll just assume yours is correct to the diagram.
