Question: 1981 Tachometer wire
dap220
Chesterland, OH
1981 Burgundy Metallic Coupe - 4 Speed
Hi All,
Would anyone know where I could get a wiring diagram for everything coming out of the fuse box?
I am particularly interested in the wire from the fuse box to the #1 connection on the tachometer.
The fuse in new and tests good, there is power on both sides of the fuse socket.
On the tach cluster I get a good reading on the socket from the distributor but nothing from the 12v socket.
Any input will be greatly appreciated.
Dale
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
You should purchase the factory repair manual.it is the bible for repairing our Corvettes.
I believe there is a wiring schematic in it
Sent from my XT1650 using Tapatalk
bill81vette
Moderator
Troy,NY
I'll check mine when I get home on Saturday
dap220
Chesterland, OH
I have the assembly manual but its not in there.
I'll look for a repair manual.
Thanks for the reply.
dap220
Chesterland, OH
Hi, I'm back.
When I first replaced the tach module some of the indicator lights and turn signal lights worked, not all in the dash though. I replaced the tach module and all dash indicator bulbs and now none of the lights work and the tach still does not also.
I got a shop manual and found that the pin and pink/black wires supply the power so I am going to pull the entire assembly out and be sure those wires are connected and hot.
Thanks for your reply, any other ideas will be greatly appreciated.
Dale
