- Thread starter
- #41
jeanie2002
Yes, the oil pressure switch could be going bad, since the unit supplies voltage for the pump on one side, and voltage for the gauge on the other lead. You should be running 40-45 PSI at cold idle and 20-25 PSI at hot idle with it goig back up to 40 or so above 1000 RPM. You might want to clean up the switch connector contacts first to make sure you are getting a good connection. You might also try fitting an oil pressure gauge on the switch fitting to double check your pressure readings in case the oil pump pressure really is going too low.
Hello, I checked out the TPS and it tested fine, someone told me the EGR valve could possibly be bad so I pulled the line off and stuck a bolt in it as a plug and seems to be running fine now, it seems to be idling too high and will still cough but only when stomping pedal to the floor. Anyway wife has been driving daily now. But like I mentioned before when this sets something different goes wrong every time I get in it. This week the wipers and pass. window quit. the wipers will work but only on the wash cycle, probably the switch???? Well I want to say a special thanks to you and everyone for the advise, Thank You very much.
