Okay, took some time today and took off the interior door panels as my power door locks showed their age:
Only the driver side would lock the car, no unlocking at all from either or locking from the passenger side.
Took the driver side out and all 5 points were corroded, fair enough, cleaned them up, stuck them back in. No change..
ad Ok, off to the Shop Manual, ahh, they are wired together. Taking out the passenger side one, corroded as well. Cleaned it up. Stick it on and now only locking works from both sides, no unlocking. :confused
Tried to swap the switches. Nothing works that way. .
So i check on the ground on the passenger door, take it out. It doesnt really look like it's catching any metal there, but so be it, cleaned it up, nada. To pry off the switch from it's 5 hole brother, i made the mistake and take a flat screwdriver. ZAAPP. 20AMP breaker, toast. Yep. great project so far.. ;squint:
Found an old 20A and stuffed it in and it's back to previous. I am guessing from reading all of the posts about door locks, that one of the cables is either broke and is loosing current? I am a numpty when it comes to measuring this stuff.. How do i measure whether current is flowing through to the door switches? I have a Digital Amp Meter, but someone needs to give me basics pls. Such as: Set Meter to XXmA and put red pin to ?? and black pin to ??...
I dont have another 20AMP to fry.
hnoes
Thanks in advance.
-Stefan
ad Ok, off to the Shop Manual, ahh, they are wired together. Taking out the passenger side one, corroded as well. Cleaned it up. Stick it on and now only locking works from both sides, no unlocking. :confusedTried to swap the switches. Nothing works that way. .
Thanks in advance.
-Stefan
