K
kamarossrs
Hi, i hope someone out there can help with this, i just picked up a 82 vette, its nothing special its driver quality and it was CHEAP,,,,anyway, the pass wheel is not centered in the wheelwell, it is toward the back of the wheelwell, the driver side wheel is centered and looks normal, but the pass side is def further back in the wheelwell, both tires are the same size 235/70/15, i dont see any visable frame deformitys and the car drives straight as a arrow, no problems,i had a 80 last summer and i thought i remembered a similar scenario, but i cant remember, the car has def had some body work done so im not sure if it may just be a case of someone putting on a fender way out of place??? any help would be appreciated, you can email me at kamarossrs@aol.com
